A ground problem
A project log for Controlling a cctv camera with arduino!
A dream school project: control one or more cctv cameras with only a arduino
pixelboPixelbo 02/14/2022 at 13:041 Comment
A short log for exposing a main problem: the rx pair of cable have too much noise (the ones that comes from the camera)
To be precise when I input a command for the camera, it drives the motor and just after I call a query for the pan position but the motor has just been driven so the cable have too much noise leading to incomplete result on my esp.
If I don't run the motor it works fine but there is still too much noise:
I know that rs485 work with voltage potential so I know that the cables at school are all the same so there is no ground connection on the cable and I won't make one for now.
So what I need to do here is to find a solution with the modules.
See you next time !
Pixelbo wrote 02/14/2022 at 17:47 point
Little update: I have ordered 5 rs485 modules from amazon, it'll be there the 16/02, so the software and hardware will wait :(
