With increases in PCB complexity and component densities, selective soldering is a popular technique for mixed technology PCB boards containing a small number of through hole joints or components.  You can use a selective solder machine to replace more time-consuming and expensive systems using wave or hand soldering with fixtures – systems that are also not as repeatable.
    Reference equipment link:
   Ersa Selective Soldering Systems
Vector Selective Soldering Machines
Mini Selective solder machine  base on Electromagnetic solder pump. While electromagnetic solder pumps used for selective soldering have several functional advantages, at the same time they inherently have several limitations.
Advantages:
This project uses  solder pot base on  Electromagnetic solder pump    link
LongLife solder nozzle ,compatible with Kurtz Ersa
SPECIFICATIONS
Maximum PCB Size              320 mm x 250 mm
Minimum PCB Size              50 mm x 50 mm
PCB Thickness                  0.8 mm - 3.0 mm
PCB Warp                     0.5 mm  maximum
Maximum PCB Weight           2 kg  including components
Component Lead Length          4 mm recommended maximum
PCB Edge Clearance             3 mm for components ;5 mm for solder pad edge
Positional Accuracy            ±0.01 mm
X-Axis Resolution              0.01 mm
Y-Axis Resolution              0.01 mm
Z-Axis Resolution              0.01 mm
Travel Speed (While Soldering)   Programmable from 0.1 mm/sec - 50.0 mm/sec
Travel Speed (Between Points)   500 mm/sec maximum
Solder Types        Both Lead-Free and Conventional Sn/Pb Solders; Second Separate Solder Pot Recommended
When Using Both Types
 Nozzle Type        2.5, 3.0, 4.0, 5.0, 6.0, 7.0, 8.0, 9.0, 10.0, 12.0,14.0, 16.0, 20.0 mm Inner Diameter Nozzles Available
Solder Pump Type               Electromagnetic solder pump
Solder Wave Height              3~6mm
Solder Wave Height Adjustment    Controlled by Fieldbus (RS485/CAN etc.)
Solder Wave Height Accuracy      ±0.1 mm
Solder Pot Capacity            Approx. 8kg
Solder Temperature           4000C maximum (6000C optional)
Solder Melt Time at Startup    Approx. 20 min.
Controller                 Embedded motion controller  or   Industrial x86
User Interface              Push-Button Controls and 15.6" Touch Screen Display
High-precision spray fluxing      optional
Live Camera                  optional
Marker Camera                optional
Nitrogen generator           optional
Automatic Solder Feeder      optional
Fume extraction              optional
Nitrogen Supply          0.4 - 0.5 MPa (60-75 psi); 25 l/min (0.9 CFM)
Machine Dimensions      920 mm L x 600 mm W x 550 mm H
Machine Weight          240kg
Power Source            Single Phase,220 VAC, 50/60 Hz,2 KVA
3D model design
Continue --------------------------------------------------------------------------============================
Demo Version 1
