New soldering pot for mini selective solder machine
A project log for Mini Selective solder machine
base on electromagnetic pump
martinzmartin.z 11/17/2022 at 01:093 Comments
New  soldering  pot  for  mini selective solder machine , add  N2 heating
paulvdh wrote 08/14/2023 at 11:52 point
I just found this project because I did some searching because I was curious if it's feasable to build a selective soldering system with DIY methods. The pump itself is the most (only?) critical part.
According to the document linked to below, such a pump costs around EUR11000 and you need an inverter which also costs around EUR4000. For a DIY person this is simply prohibitively expensive, but a DIY person also does not have the same extreme reliability and longevity demands that are put upon high production volume equipment.
https://azcscxpprodcdn.azureedge.net/-/media/Files/Nordson/select/Soldering%20Processes/Myths%20and%20Realities%20of%20Electromagnetic%20Solder%20Pumps.pdf
martin.z wrote 08/14/2023 at 15:07 point
Hello Paulvdh,
Regarding the points you mentioned:
Price-wise, we have managed to bring down the cost of the complete soldering system to 4000 euros, and for the electromagnetic pump, the lower-end prices are now within 1000 euros in China.
While electromagnetic pumps may seem costly, they offer stable wave soldering and have a long lifespan. We have developed various specifications, including low-cost, high-temperature, and high-power electromagnetic pumps. In China, the cost of selecting a wave soldering equipment with an electromagnetic pump is now below 30000 euros.
Of course, for DIY projects, you can achieve even lower prices.
