[EM] Pins and the GPIO Matrix
A project log for Tetrinsic [gd0041]
A continuous, motorised fader that is force sensitive and haptic.
kelvinakelvinA 06/14/2023 at 01:150 Comments
So, as it turns out, the ESP32 supports the ability to route any GPIO to any physical IOx pin... at least... that's what I understand from trying to figure out the SPI pins.
That means that my symbol is kind of lacking, and so I've revamped it:
As you can see, I've also started lining up the pins I need, and I only have 6 - 7 pins left for I2S (depending on if the ADC gets its own clock or not), 2 displays and an addressable RGB pin. The 8-bit shift register might make a comeback.
I've decided to expose both I2C channels for versatility (such as reducing traffic on an I2C bus), and to allow me to support communications with 4 Toshiba HDMI->MIPI chips for #Leti.
