[L] 3DPCB
A project log for Tetrinsic [gd0041]
A continuous, motorised fader that is force sensitive and haptic.
kelvinakelvinA 06/23/2023 at 04:070 Comments
This PCB looks cooler when all the vias are installed.
It's easy to see that the ADC, encoder and BLDCC (BLDC Controller) are in a line for the aesthetic:
It took a few tries to tweak the location of the "Tetrinsic" text since there's now a row of vias cutting into it:
It's likely fine, as it turns out that this entire thing is about the diameter of a 2 pence coin...
...yet it looks like a city metro when I hide the GNDPlane:
And yes, I have just seen and aligned those 2 vias on the edge where the load cell pad is. (And after writing this log, I went to further refine the traces, such as eliminating acute angles and thickening traces that could use it, such as +3.3V.
I'm certainly going to need to get a vacuum pen thing because tweezers probably aren't going to suffice.
