• 1
    Wiring Diagram
    AMB21 / AMB22 Wiring Diagram:
    Connect the 3.5mm connector to the RTL8722 board following the diagram.
    1
    AMB23 Wiring Diagram:
    As RTL8722DM MINI has a built-in microphone on the board, there is no need for any external microphone.
  • 2
    Compile and Upload example
    Open the example, “Files” -> “Examples” -> “AmebaAudioCodec” -> “OutputSineWave”.
    1
    Upload the code and press the reset button on Ameba once the upload is finished.
    Connect a pair of wired headphones to the 3.5mm audio jack and you should hear the generate single sinusoidal tone.
  • 3
    More References
    Please visit the following websites for more details about the board & other examples:
