Trying it out on pegboards!
A project log for EL Wire on Geoboards/Pegboards
Using EL wire on a geoboard to create glowing shapes and designs. And now on Pegboards!
thinklearndoThinkLearnDo 06/04/2022 at 22:460 Comments
I tried it out with pegboards, and it worked great! Simply weave the el wire through the holes in the pegboard and create simple shapes.
 Then turn off the lights and turn on the EL wire.
Thinner EL wire works better, you can fit more through each hole that way.
