The Latest Firmware Support
A project log for Meshtastic Mesh Device Nano Edition
A compact Lora device with high efficiency internal compact Lora PCB Antenna, ultra-low noise figure amplifier and internal GPS module. This
neil-haoNeil Hao 05/17/2022 at 05:170 Comments
Meshtastic Mesh Device Nano Edition G1 had been supported by the official meshtastic repository on Github from firmware version 1.2.61. Thus, the latest firmware could be downloaded from the meshtastic project’s releases page: https://github.com/meshtastic/Meshtastic-device/releases
 Firmware file: firmware-nano-g1-1.x.x.bin
The Fimware may also be updated by using Meshtastic GUI Installer. Meshtastic GUI Installer is a cross platform, easy to use GUI for installing Meshtastic firmware.
More Info:https://meshtastic.org/docs/hardware/supported/nano-g1
