Tired of shaky breadboard connections and rat's nest of wires, but not confident enough to design a proper PCB, so I'm moving eveything to stripboards. I'm also looking at making a new enclosure/containers with PVC pipes. In the meantime, my momentum will slow a bit as I've got other priorities popping up.
Quick-and-dirty PCB design (red lines are trace cuts, blue lines are bridge wires, didn't bother with component values, just layout).
I've taken the feeder back inside to do this work. Hope to finish the proto-PCB and new enclosure before the end of August.
