USB C cable tester
USB C to USB C cable tester to find out which type of you have (USB 2.0, 3.0, Power Delivery, ...)
qcQC
Starting from
$29.90
petl has 1889 orders / 23reviews
Ships from Austria
The C2C caberQU board applies a voltage to all pins of a cable and measures which ones are connected to the other end. It features LEDs for each of the 24 pins and even shield. So in total 25 LEDs offer all possible combinations for USB-C receptacle pin usage in different modes:
USB 2.0/1.1
USB Power Delivery
USB 3.0/3.1/3.2
Alternate Mode
Debug Accessory Mode
Audio Adapter Accessory Mode
The amount of possible USB C cable combinations is endless. If you  use the wrong cable, data transmission may be slower than possible or  certain devices may not work at all. In the USB C standard, the cable  plays an important role and has to advertise itself as such. All of them  need to have certain pins connected, some need to be grounded, some  need to have resistors attached.
What makes it special?
Unfortunately there is no easy way to extract whether a certain cable  can support a certain use case. If a cable has a broken pin, that makes it even worse, due to their unpredictable behavior. The C2C caberQU cable tester solves this once and for all. By flipping the USB  connectors, the opposing LEDs for some pins light up due to them not  being mirrored. That's on purpose and defined in the USB C standard. The  product is sold with one CR2032, the PCB and some basic instructions.  The USB C cable is not included. You have to extract the needed pins for  your desired usage on your own, unfortunately that can not be done  universally for all possible combinations. No dedicated power supply is needed, all necessary power is supplied  via the CR2032 battery. The battery is only discharged when a cable is  connected and should last for a while.
The item still is a  prototype. It is working as intended, but funny quirks and other things  are possible. It is not certified, comes as a kit and only suited for prototyping. No soldering or any difficult assembly is needed.
If you have any questions, just shoot me a message!
View project log
thegoldthing wrote 08/12/2023 at 12:36 point
How would this behave with an active thunderbolt 3 cable?
I imagine it won't work properly, but is there any risk of damaging the active circuitry?
Thanks.
