First try on a tripod
A project log for How to use an aerial 36 inches lens
the different steps involved to shoot with an aerial photographic (enormous) lens when you don't have the airplane to hold it
zit-olivier-gade[zit] Olivier Gade 04/27/2022 at 10:410 Comments
The 3/8" threaded hole has been drilled around the center of balance of the lens, it's a little bit in front of the diaphragma as the front element glasses are bigger than the rear ones, as a telephoto lens, it isn't a symmetrical formula.
The piece of bicycle inner tube (left down the lens) is absolutely not necessary : there's no contact between the lens and the aluminium profile, and it does not move at all, but for the first try...
