Reinforcement
A project log for How to use an aerial 36 inches lens
the different steps involved to shoot with an aerial photographic (enormous) lens when you don't have the airplane to hold it
zit-olivier-gade[zit] Olivier Gade 05/17/2022 at 15:490 Comments
The rolling system's been tested and validated : the blade glides perfectly !
It must be strengthen by adding another screw on each of the four lower corners, only 1 M 3 screw for the violence of the movement is not serious at all, but I wasn't sure of the assembly, so I've been lazy.
I feel relieved.
That last screw on the front needed another tourne à gauche (taping tool) as I didn't want to disassemble everything, but it was close.
