Thanks for Checking this Project Out!
Hi! Thanks for checking this project out. It's is a huge undertaking and is part of a much larger set of undertakings that I believe might just make a HUGE impact in the world. Sound crazy? Maybe I'd have to be a little crazy to even think I could do this. Oh well! I accept that I am a bit crazy... just the right amount! Are you? Check out all my projects at WeeHaven.org, and let me know if you want to jump in the deep end of the pool with me! I could use the help!
Links to Relevant WeHaC Project Details
Here's a list of current project files: I'll try and update this list as needed.
External Sources of info, products & tools not under Wee Haven Control
  • LinuxCNC.org - The software platform for the system. It's one of the best and most flexible systems out there!
