Nozzle Collision Sensing
A project log for Fast Bed leveling sensor
High resolution Distance sensor for 3D printer Bed Leveling
markmark 04/17/2024 at 06:580 Comments
Benefit:
  1. Avoid the temperature drift.
  2. Auto z_offset Calibrate From the data bellow we can see that the temperature drift will only change the z_offset, rise or low the bed mesh, but does not change the bed mesh with this BDsensor. that means the bed mesh is the same even with different temperature.
3. Repeatability: +/-0.005mm
Nozzle Collision Sensing with eddy BDsensor (pandapi3d.com)
