New hardware revision?
A project log for All-In-One Gamma-Ray Spectrometer
More sensitive to gamma radiation than a Geiger counter with the added bonus of telling exactly what's inside your samples!
nuclearphoenixNuclearPhoenix 09/20/2023 at 15:550 Comments
To break the silence, here is a short update on what's going on behind the scenes right now.
At the moment we're looking into a possible hardware revision 4. This one mostly focusses on the PCB and component layout to improve shielding and optimize the total device size. There is a lot that can still be done in this regard and we'll test it thoroughly before release. In the best case this will keep on improving the energy resolution of the device and the new revision will also include some smaller quality of life improvements. Follow the project so you don't miss out on any updates.
On another note, the OGD is sold out on Tindie, so thank you all for your interest in this project and the support. You can still get some of the Tiny MicroFC breakout boards if you want, the sale is still on until the end of september.
Cheers!
