Designed a separate Enclosure ( V2.0 ) for STEM Education PCB
A project log for DIY Solar Bottle Lamp
Solar Bottle Lamp is a solar-powered light that is constructed from waste plastic bottles. The design idea is to reuse waste plastic bottles
open-green-energyOpen Green Energy 05/09/2022 at 08:300 Comments
Designed a dedicated enclosure to fit the new PCB for STEM education.
The enclosure has 5 parts:
1. Main Body
2. Top Cover
3. LED Holder
4. Diffuser
5. Button
The Main Body is basically designed to fit all the components including the battery. The top cover is to cover up the main body and mount the solar panel on it. The LED holder is used to hold the LED and the diffuser is used to diffuse the LED light in all directions. The button is used to operate the switch on the PCB from outside.
Download the .STL files from Thingiverse.
You need a support structure for printing the main body and top cover. You can print the enclosure parts either in PLA, ABS, or PTEG filament.
I am trying to modify the design so that it can be printed without support.
