Tested the Circuit
A project log for DIY Solar Bottle Lamp
Solar Bottle Lamp is a solar-powered light that is constructed from waste plastic bottles. The design idea is to reuse waste plastic bottles
open-green-energyOpen Green Energy 10/24/2022 at 01:390 Comments
I have tested the circuit as per the above setup. The PCB is working as expected. I have also tested the backup time and the following are the actual results
1. Mode-1: LOW Brightness -  26 Hrs
2. Mode-2: MEDIUM Brightness -  12 Hrs
3. Mode-1: HIGH Brightness -  7 Hrs
