OpenDendrometer v0.1 Material Cost Estimate
A project log for OpenDendrometer
monitor the health of trees and fruit
john-opsahlJohn Opsahl 10/16/2022 at 01:530 Comments
The current material cost estimate for a single OpenDendrometer v0.1 is $50 USD. See cost breakdown by component in the table below. The two highest cost items are the lithium battery and the enclosure at around $7.75 each. $50 falls right in the middle of the "shall" requirement of $60 and "should" requirement of $40 that were established at the beginning of this project. Overall, I am excited to have achieved the original design requirements and look forward to exploring strategies to further reduce material cost.
For more a more detailed breakdown on these costs and information on where these components can be sourced from, see the "eBOM" spreadsheet of the "OpenDendrometer_EN" workbook in the files section of this project.
Qty  Description Cost Per Unit Total Cost
1 digital tire tread depth gauge $4.27 $4.27
1 Arduino Pro Mini, 3V/8MH $2.12 $2.12
1 lithium battery, 2000mAh $7.67 $7.67
1 micro SD card module $0.38 $0.38
1 micro SD card, 16GB HC $1.99 $1.99
1 RTC module, DS3231 $3.75 $3.75
1 coin cell battery, 2032 $0.61 $0.61
1 logic level shifter, 4 channel $0.30 $0.30
1 mosfet, 2N7000 $0.14 $0.14
1 Bluetooth BLE module, AT-09 $4.05 $4.05
1 OpenDendrometer PCB $4.00 $4.00
2 6 position header connector 2.54mm, through hole, right angle $0.66 $1.32
1 JST B2B-PH-K, 2mm spacing,1 row, 2 contacts $0.01 $0.01
1 OpenDendrometer laser cut parts, baltic birch plywood, 3.18mm $4.00 $4.00
1 electronics enclosure, 158x90x60 $7.84 $7.84
1 shaft collar, 1.6mm shaft $1.68 $1.68
1 aluminum angle, 25x25mm, 1.6mm thick, 130mm long $2.50 $2.50
4 nut, M5, stainless $0.06 $0.23
2 threaded rod, M5, stainless, 100mm $1.50 $3.00
Total $49.85
