I2C u no workin?
A project log for The Atmega Hearth
Lets imagine a cheap core for all your breadboard µC Projects.
stefan-xpStefan-Xp 07/30/2015 at 21:393 Comments
I just tried to attach the TLC59116 [https://hackaday.io/page/818-hmmm-what-about-an-i2c-port-led-driver-ic] to the Atmega Hearth. Unfortunately it is not working.
Not sure why. Perhapps i have to try it again with external 16MHz crystal.
Do you have Ideas why it couldn't be working?
The same sketch works at a Atmega328p...
davedarko wrote 07/30/2015 at 22:44 point
It could be anything - wrong pins, no pull-up resistors on SDA and SCL, wrong I2C address? Not so sure about the timing, but even if it's a wrong crystal it still should work, since it's the master? Have you tried another atmega hearth and I2C modules, just to make sure?
Stefan-Xp wrote 08/01/2015 at 09:14 point
I tried Pullup Resistors and 16MHz crystal. Still not working :(
I'm on Vacation after that i will try to use anoter I2C Device...
Stefan-Xp wrote 09/10/2015 at 22:11 point
Well... the pcf8574 works with the ATMEGA16. The TLC still refuses to work properly... it looks like it gets resets or misses some steps idk.. :-(
