Andere Anzeigen
A project log for Dot flippers
or "flip dotters" if you want. Let's just talk about flip-dot/flip-disc displays and projects using them :-)
yann-guidon-ygdesYann Guidon / YGDES 12/09/2016 at 23:462 Comments
Good news, european fellows : the magic of eBay has struck again :-D Look at these beauties:
Like the previously seen LUMINATOR arrays, they are 28 dots wide, but 19 dots high instead of 16. That's why I took the display with the three broken dots : it's cheaper and I don't need the bottom 2 rows. That's 17 lines and I can still show the parity bits :-)
OK I also ordered the pristine one. But the seller still has other modules for sale at the time of writing (the 2 last links). Watch the seller http://www.ebay.com/usr/motozentrum in case more became available...
The shots of the back show the pairs of steering diodes and the matrix is very simple so I expect no surprise. I can un-socket the IC and do my things...
Unlike the LUMNATOR the PCB doesn't implement the magnetic coil, so I'm curious.
Ô the things I could do with them... ;-)
SHAOS wrote 12/10/2016 at 02:43 point
> (this one is still for sale)
not anymore ;)
Yann Guidon / YGDES wrote 12/10/2016 at 02:46 point
damnit ! bad copy-paste, sorry...
I have seen 2 arrays still for sale, I must update the log...
