Squeezing the code because 85 bytes is too many...
A project log for Joy232
Print using RS232 on the joystick port of MSX computers
danjovicdanjovic 12/10/2016 at 14:170 Comments
I have started to squeeze the hook code. This can be done by merging the start, stop and data bits into a 16 bit register and use the same loop to transmit all the bits from the RS232 character (i.e. 10 bits). It also has a positive side effect that now all the bits will last exactly the same time (the stop bit may linger but it doesn't really matter as long as it takes at least 1 bit time.
Then the bitbang code turns into:
SND232:
; Inputs:
; L: Byte to be sent
; Changes: AF, BC, HL
; Select PSG Register 15
LD A,15
OUT [PSGAD],A
; Prepare stream of bits
LD H,255; Add stop bits
AND A   ; clear carry flag
RL L    ; Add start bit and send 7th bit to carry
RL H    ; Send 7th bit to H register
        ; HL register is now
        ; ------------ H -----------    ----------- L ---------
        ; 16 15 14 13 12 11 10  9  8    7  6  5  4  3  2  1  0
        ;  1  1  1  1  1  1  1 stp b7   b6 b5 b4 b3 b2 b1 b0 start
; Now loop through 10 bits [1 extra to compensate time at the end of the loop]
LD B,10+1  ; poke here with 12 to send two stop bits instead of only one
SEND_BITS:
   ; prepare mask ; Cycles  Accumul
   IN A,[PSGRD]   ;  14     24      save the present state of the bits from PSG register 15
   RES 0,A        ;  10             clear bit 0
   ; 16 bit rotate
   RR H           ;  10     20      H.0->Cy (bit 0 from H goes to carry)
   RR L           ;  10             Cy->L.7, L.0->Cy
   ; set TXD line state
   ADC A,0        ;   8     20      A.0 now equals Cy
   OUT [PSGWR],A  ;  12             write bit to output. Here starts the cycle counting
   ; delay 1 bit time
   LD C,_DLY      ;   8     8      poke here to change the cycle count
   DELAY_C:
   DEC C          ; ( 5)
   JP NZ DELAY_C  ; (11)
                  ; 16*_DLY
DJNZ SEND_BITS    ; 14(/9)         send next bit
                  ;Total:  8 + 16*_DLY + 24 + 20 + 20 from Start bit to beginning of stop bit
                  ;        72 +16*_DLY cycles
                  ; after the last bit we have:  8 + 16*_DLY + 9
                  ;                              17 + 16*_DLY
                  ; we're missing 72-17 = 55 cycles that's why we added 1 to ensure that
                  ; at least 1 stop bit time has passed before we return
RET
