SLA Spool Print
A project log for One Handed Manual Solder Feeder
A contraption to help feed solder efficiently single handed.
mulcmumulcmu 07/23/2023 at 22:450 Comments
The first test print of the spool with resin didn't turn out so well.  Lost a lot of the supports on the feeder, the lid failed completely.  After chasing the threads with a die the feeder fit nicely with the spool holder.  The  spool holder still had the center hole sized for heat set insert.  I tried to install one with extra heat but ended up splitting the mounting location.
Last time I used this resin was winter and space heaters were used to keep printer warm.  Side project started to add a heater to the resin printer.
The spools turned out nicely.
