The bone Image
A project log for CT system Revamp
The most probable failure to decommissioned a system is Image Processing Unit Hardware. Here a way to Rescue it, using Open Source solutions
proyectosyprototiposproyectosyprototipos 07/19/2023 at 16:490 Comments
here, the Xray image produced by the cow's bone in that position.
well... to be more clear, the Xray path is from above the bone, to bottom; the dark circle where the bone is located, is the entry face of the detector. this detector is called Image Intensifier
