to be clear
A project log for CT system Revamp
The most probable failure to decommissioned a system is Image Processing Unit Hardware. Here a way to Rescue it, using Open Source solutions
proyectosyprototiposproyectosyprototipos 07/19/2023 at 17:070 Comments
the previous image is not a reconstruction. is the result of Xray the bone as is in this photo.
however, the image result would be something like that, after the process.
at this time, i'm almost able to do the whole experiment to see if this could be viable.
