Yesterday was New Year and the little bird noticed the fireworks going off around midnight (please see the image below). All that noise and the flashing lights seem to cause a lot of stress for birds even when they are inside a birdhouse.
I also implemented the temperature compensation for the weight graph using a formula data field in DataCake. The formula adds/subtracts an offset to the weight depending on the temperature inside the birdhouse (please see the older posts). The baseline of the weight graph should now be closer to zero without being affected too much by temperature. Using the formula data field also gives me the chance to adjust the math for the temperature compensation online instead of having to do a software update of the birdhouse each and every time.
