All modules are done
A project log for BrainfuckPC Relay Computer
Von-Neumann 16-bit relay computer with Brainfuck++ instruction set
artem-kashkanovArtem Kashkanov 07/20/2018 at 19:094 Comments
Last modules for BrainfuckPC are Done!
Overall modules count: 157pcs.
Relays:
RES55 - 439pcs
RES64 - 75pcs
RES43 - 64pcs
Current number of relays - 578pcs
Blair Vidakovich wrote 07/22/2018 at 08:14 point
you got your girlfriend to do the soldering?? how did you convince her? mine would never do it...
Artem Kashkanov wrote 07/22/2018 at 12:01 point
Just showed her how to solder SMD components :)
Jan wrote 07/21/2018 at 08:36 point
What was your build time for all the modules? Did you have friends over for soldering? You used at least 500g of solder, right? ;)
Artem Kashkanov wrote 07/22/2018 at 07:10 point
"Dirty" time is about 8 month. "Clean" time I think about 200 hours. And most part of modules we done by my girlfriend :-)
Only 200g of solder were used for doing this.
