Power line +5V improvement
A project log for BrainfuckPC Relay Computer
Von-Neumann 16-bit relay computer with Brainfuck++ instruction set
artem-kashkanovArtem Kashkanov 10/02/2018 at 09:000 Comments
I found significant voltage drop on high speed, so I added direct copper line 0,25x11 mm to each data module. I can be sure that this would be enough to good power delivery. Power line resistance now is less than 10 mOm.
