We all know that theory is often not reflected in practice.
Could I submit a sensor network project, claiming a network of 60 sensors without being sure it worked?
No! I had to be sure, so I decided to test if my theoretical calculation was correct.
The following video shows the tests carried out.
Why 60 modules limit?
Green detect wireless sensor network uses ESP-NOW protocol.
The first ESP-NOW technology limitation is that the total number of peer devices should be less than 20.
How did I exceed this limit?
I simply created a chain network, where each device communicates with 2 other devices the one from which it receives the packets and the one to which to send the processed packets.
Basically I created many small networks, exceeding the limit of 20 devices.
Why can Green Detect network include a maximum of 60 devices?
Because the ESP-NOW technology has another limitation: up to 250-byte payload can be carried.
And since I have foreseen 4 bytes of transmission per sensor, I can use a maximum of 60 sensors (60x4 = 240 bytes)
