Printout #1
A project log for Starship incense holder
Making frankincense multiplanetary
lion-mclionheadlion mclionhead 06/28/2022 at 09:270 Comments
It should have a 5mm wider radius & be shorter.
Ash collection was as expected.   Some of it went all the way through the launch mount to the table.  The mane idea was to stop it from blowing sideways.
It should be noted Out of Darts uses exclusively direct drive extruders, dual Z drives, dual Y rails, induction bed leveling.  Those PRUSA I3's were beasts.
The lion kingdom's direct drive solved the extrusion jams, but now the X axis has a sag.  The next upgrade now should be an Ender 5 plus.
