4. ModusToolbox Software
A project log for Smart Mini Elevator
Old scanner hacked and turned into smart mini elevator
guillermo-perez-guillenGuillermo Perez Guillen 06/27/2022 at 20:410 Comments
I downloaded and install the software ModusToolbox 2.4 in its version for Windows
I recommend you follow the instructions in this webinar, since some steps will serve as a reference: Implementing Machine Learning on the Edge
To develop my project, I will use the next code demo as a reference: "Picovoice_Porcupine_Wake_Word_Demo".
Step 1. Click on: File> New> ModusToolBox Application
Step 2. Insert kit name: CY8CKIT-062S2-43012, and click next
Step 3. Select "Picovoice_Porcupine_Wake_Word_Demo" poject, and click on create. Below is the project:
Step 4. Open main.c file and make the next changes:
// AUTHOR: GUILLERMO PEREZ GUILLEN
#include <stdbool.h>
#include <stdio.h>
#include <stdlib.h>
#include "cy_rgb_led.h"
#include "cybsp.h"
#include "pv_audio_rec.h"
#include "pv_keywords.h"
#include "pv_porcupine.h"
#include "pv_psoc6.h"
#include "cy_pdl.h"
#include "cyhal.h"
#include "cy_retarget_io.h"
#define MEMORY_BUFFER_SIZE (70 * 1024)
static const char* ACCESS_KEY = "gkylTu/7ljkHnB1/yobm78094/ea8DZ59MN7xcgWduJU1278u6AyGg=="; // AccessKey string obtained from Picovoice Console (https://picovoice.ai/console/)
static int8_t memory_buffer[MEMORY_BUFFER_SIZE] __attribute__((aligned(16)));
#define DELAY_LONG_MS           (2)   /* ADD 2 milliseconds */
#ifdef __PV_LANGUAGE_ENGLISH__
static const int32_t NUM_KEYWORDS = 4;
static const int32_t KEYWORD_MODEL_SIZES[] = {
        sizeof(DEFAULT_KEYWORD_ARRAY),
        sizeof(PINKY_KEYWORD_ARRAY),
        sizeof(BUMBLEBEE_KEYWORD_ARRAY),
        sizeof(ALEXA_KEYWORD_ARRAY)
static const void *KEYWORD_MODELS[] = {
        DEFAULT_KEYWORD_ARRAY,
        PINKY_KEYWORD_ARRAY,
        BUMBLEBEE_KEYWORD_ARRAY,
        ALEXA_KEYWORD_ARRAY
static const float SENSITIVITIES[] = {
        0.75f,
        0.75f,
        0.75f,
        0.75f
static const char *KEYWORDS_NAME[] = {
        "Porcupine",
        "Pinky",
        "Bumblebee",
        "Alexa"
#else
static const int32_t NUM_KEYWORDS = 1;
static const int32_t KEYWORD_MODEL_SIZES[] = { sizeof(DEFAULT_KEYWORD_ARRAY) };
static const void *KEYWORD_MODELS[] = { DEFAULT_KEYWORD_ARRAY };
static const float SENSITIVITIES[] = { 0.75f };
static const char *KEYWORDS_NAME[] = { "" };
#endif
static void error_handler(void) {
    cy_rgb_led_on(CY_RGB_LED_COLOR_RED, CY_RGB_LED_MAX_BRIGHTNESS);
    while(true);
int main(void) {
    uint32_t delay_led_blink = DELAY_LONG_MS;
    cy_rslt_t result;
	result = cyhal_gpio_init(P0_2, CYHAL_GPIO_DIR_OUTPUT, CYHAL_GPIO_DRIVE_STRONG, CYBSP_LED_STATE_ON);
    result = cyhal_gpio_init(P0_3, CYHAL_GPIO_DIR_OUTPUT, CYHAL_GPIO_DRIVE_STRONG, CYBSP_LED_STATE_ON);
    result = cyhal_gpio_init(P1_3, CYHAL_GPIO_DIR_OUTPUT, CYHAL_GPIO_DRIVE_STRONG, CYBSP_LED_STATE_ON);
    result = cyhal_gpio_init(P13_6, CYHAL_GPIO_DIR_OUTPUT, CYHAL_GPIO_DRIVE_STRONG, CYBSP_LED_STATE_ON);
    if (result != CY_RSLT_SUCCESS)
        CY_ASSERT(0);
    pv_status_t status = pv_board_init();
    if (status != PV_STATUS_SUCCESS) {
        error_handler();
    status = pv_message_init();
        error_handler();
    const uint8_t *board_uuid = pv_get_uuid();
    printf("UUID: ");
    for (uint32_t i = 0; i < pv_get_uuid_size(); i++) {
        printf(" %.2x", board_uuid[i]);
    printf("\r\n");
    status = pv_audio_rec_init();
        printf("Audio init failed with '%s'\r\n", pv_status_to_string(status));
        error_handler();
    status = pv_audio_rec_start();
        printf("Recording audio failed with '%s'\r\n", pv_status_to_string(status));
        error_handler();
    pv_porcupine_t *handle = NULL;
    status = pv_porcupine_init(
            ACCESS_KEY,
            MEMORY_BUFFER_SIZE,
            memory_buffer,
            NUM_KEYWORDS,
            KEYWORD_MODEL_SIZES,
            KEYWORD_MODELS,
            SENSITIVITIES,
            &handle);
        printf("Porcupine init failed with '%s'\r\n", pv_status_to_string(status));
        error_handler();
    while (true) {
        const int16_t *buffer = pv_audio_rec_get_new_buffer();
        if (buffer) {
            int32_t keyword_index = -1;
            const pv_status_t status = pv_porcupine_process(handle, buffer, &keyword_index);
                printf("Porcupine process failed with '%s'\r\n", pv_status_to_string(status));
                error_handler();
            if (keyword_index >= 0) {
                printf("[wake word] %s\r\n", KEYWORDS_NAME[keyword_index]);
                switch (keyword_index) {
                    case 0:			// 1 -> 2 or 2 -> 3
                        cy_rgb_led_on(CY_RGB_LED_COLOR_GREEN, CY_RGB_LED_MAX_BRIGHTNESS);
                        for (int i = 1; i <= 800; i++){
    	                    cyhal_gpio_write(P0_2, CYBSP_LED_STATE_ON);
    	                    cyhal_gpio_write(P0_3, CYBSP_LED_STATE_OFF);
    	                    cyhal_gpio_write(P1_3, CYBSP_LED_STATE_ON);
    	                    cyhal_gpio_write(P13_6, CYBSP_LED_STATE_OFF);
    	                    cyhal_system_delay_ms(delay_led_blink);
    	                    cyhal_gpio_write(P1_3, CYBSP_LED_STATE_OFF);
    	                    cyhal_gpio_write(P13_6, CYBSP_LED_STATE_ON);
    	                    cyhal_gpio_write(P0_2, CYBSP_LED_STATE_OFF);
    	                    cyhal_gpio_write(P0_3, CYBSP_LED_STATE_ON);
                        break;
                    case 1:			// 2 -> 1 or 3 -> 2
                        cy_rgb_led_on(CY_RGB_LED_COLOR_CYAN, CY_RGB_LED_MAX_BRIGHTNESS);
                        break;
                    case 2:			// 1 -> 3
                        for (int i = 1; i <= 1600; i++){
                        break;
                    case 3:			// 3 -> 1
                        cy_rgb_led_on(CY_RGB_LED_COLOR_BLUE, CY_RGB_LED_MAX_BRIGHTNESS);
                        break;
                    default:
                        break;
                Cy_SysLib_Delay(500);
                cy_rgb_led_off();
    pv_board_deinit();
    pv_audio_rec_deinit();
    pv_porcupine_delete(handle);
Analysis:
Step 5. I have added the "Pinky" wake word in the pv_params.h file. This wake word was obtained from the Picovoice platform as shown in the next section.
// Wake-word = pinky
static const uint8_t PINKY_KEYWORD_ARRAY[] __attribute__ ((aligned (16))) = {
        0xde, 0x5a, 0x0b, 0xec, 0x84, 0x04, 0xa4, 0x94, 0x5a, 0x6a, 0x1c, 0x2f, 0x62, 0xb9, 0x71, 0xc6, 0x9c, 0xf5,
        0xfd, 0xe4, 0x7e, 0xfd, 0xbd, 0xc9, 0xea, 0x4b, 0x78, 0x95, 0xd4, 0xf3, 0xbe, 0x1f, 0xbe, 0x4a, 0xf9, 0x6d,
        0xce, 0x10, 0x05, 0xdb, 0xbc, 0x88, 0xdf, 0x5d, 0xa4, 0xbd, 0xab, 0x4e, 0x9b, 0x9f, 0x2c, 0x17, 0x6a, 0x42,
        0xb1, 0xbd, 0x21, 0x8b, 0xfe, 0x7c, 0x74, 0xbf, 0xe9, 0xb8, 0x12, 0x25, 0x28, 0x1d, 0x74, 0x4d, 0x2c, 0x48,
        0x60, 0x69, 0x7b, 0x45, 0xf6, 0xc8, 0x9f, 0x42, 0x63, 0x8a, 0xe0, 0x08, 0x1d, 0xf1, 0x8a, 0xd5, 0x0c, 0x68,
        0xf0, 0x19, 0x8f, 0xd0, 0x61, 0x87, 0xd4, 0x76, 0x72, 0x67, 0xf8, 0x37, 0x04, 0x38, 0xf2, 0xcd, 0x4a, 0x70,
        0xc3, 0xcc, 0x7f, 0xc4, 0x97, 0x20, 0xf8, 0x53, 0x25, 0xa7, 0xc2, 0xf7, 0xfa, 0x3c, 0x47, 0xc2, 0x0a, 0x06,
        0x8a, 0xc2, 0xb0, 0xf8, 0x05, 0xd3, 0x8e, 0x6d, 0x2a, 0x65, 0x5f, 0xd8, 0xfd, 0xa9, 0xcf, 0xe5, 0xd4, 0x33,
        0x8e, 0xfc, 0x44, 0x72, 0x0f, 0x49, 0x3b, 0xad, 0x50, 0x5d, 0xab, 0x69, 0x17, 0xb1, 0xc3, 0x28, 0x28, 0x5a,
        0x6f, 0xd8, 0xef, 0x25, 0xab, 0xe8, 0x2c, 0x30, 0x0e, 0x1b, 0xfa, 0x4a, 0x3d, 0xf2, 0x03, 0xd8, 0x18, 0xb3,
        0x47, 0xa8, 0xba, 0xed, 0xdc, 0x65, 0xce, 0x85, 0x58, 0x3f, 0xba, 0x9d, 0x32, 0xd5, 0xc1, 0x1c, 0xef, 0xbf,
        0x85, 0xbf, 0xa1, 0x9e, 0x19, 0x60, 0x98, 0xe7, 0x30, 0x63, 0x86, 0xf6, 0x29, 0xff, 0x88, 0xa2, 0xf7, 0x94,
        0xe8, 0x80, 0x9d, 0x4b, 0x35, 0xa3, 0x43, 0x90, 0xe7, 0x85, 0x92, 0x9e, 0x82, 0x18, 0x80, 0x1f, 0x8e, 0x21,
        0x78, 0x3c, 0xa2, 0x85, 0x6f, 0xd9, 0x7a, 0x44, 0x7e, 0x9a, 0xe8, 0xac, 0x76, 0xe2, 0x5b, 0x04, 0x88, 0x64,
        0x55, 0x93, 0x95, 0x8e, 0x04, 0x08, 0x2f, 0xf4, 0x82, 0x9b, 0xa9, 0xc7, 0xf1, 0x14, 0x58, 0x73, 0xeb, 0x7f,
        0xb1, 0x99, 0x63, 0x19, 0xe3, 0xda, 0x9d, 0x2d, 0x73, 0x46, 0xc0, 0x40, 0xdf, 0xf7, 0x36, 0x31, 0xf6, 0xa7,
        0x61, 0x03, 0xb5, 0x0d, 0xc8, 0x6d, 0x7f, 0xd5, 0x4a, 0x56, 0x46, 0xf5, 0xbd, 0x69, 0x13, 0xf0, 0x57, 0xa7,
        0x0b, 0xe0, 0x49, 0x8a, 0xa5, 0x23, 0x78, 0x71, 0x4e, 0x30, 0x91, 0x1a, 0xb9, 0x38, 0xba, 0x43, 0xe1, 0x7a,
        0xfd, 0x03, 0x1b, 0xf1, 0x27, 0x0b, 0x26, 0xbb, 0xc3, 0xee, 0x11, 0x66, 0xd1, 0x29, 0x93, 0xdf, 0x7f, 0xf8,
        0x98, 0x74, 0x1e, 0x96, 0x59, 0xce, 0x11, 0xba, 0x68, 0xed, 0xf4, 0x80, 0x25, 0x4d, 0xd2, 0x3d, 0x49, 0xff,
        0x33, 0x4d, 0xdc, 0xba, 0xd2, 0x9c, 0xdf, 0x0c, 0xf5, 0x58, 0xd4, 0x5a, 0x82, 0xa2, 0xd7, 0x02, 0x17, 0xe2,
        0xa5, 0xb9, 0x5b, 0x96, 0xa0, 0xf5, 0x50, 0x47, 0x36, 0x9a, 0x55, 0x99, 0xfe, 0x08, 0x10, 0x0f, 0xd2, 0x17,
        0x4a, 0x25, 0x9b, 0x3c, 0x8c, 0x78, 0xfc, 0x35, 0x6b, 0x94, 0xd1, 0xd4, 0x39, 0x51, 0xc1, 0x77, 0x34, 0xc0,
        0x3b, 0x73, 0x50, 0x89, 0x96, 0x83, 0x2d, 0xfe, 0x95, 0x81, 0x55, 0x34, 0xdb, 0x6a, 0xbd, 0xb8, 0x9a, 0x4a,
        0xbb, 0x0d, 0xf6, 0x0e, 0x8a, 0x3e, 0xec, 0x9f, 0xc6, 0x33, 0x99, 0x39, 0x6e, 0xda, 0x03, 0xfe, 0x9a, 0x0e,
        0x7a, 0x2d, 0xa0, 0xa0, 0xfb, 0x5f, 0xe9, 0x13, 0xdc, 0x5a
