As I mentioned before, best way to know new part is to build some project based on that. After traveling with my family some time age, I had an idea to build digital safe toy for my son. He had some with the real thing, so I figured this could be a good toy at home.
- password entry using keypad
- LCD screen, symbol display controlled via I2C expander makes perfect sense here
- Buzzer and LED blinker clearly
- Li-Po Battery powered. Charging can be external
I started to look around for firmware, and immediately found Arduino Electronic Safe. I added RGB LED and buzzer support, which forced me to rewrite most of the code to run async.
