Creating a Vivado IP to program the AD9851
A project log for 32MHz spectrum + SDR + FT8 in an FPGA
A 0 - 32MHz FPGA based Software Defined Radio (AM SSB FT8) by ready modules->cheap and easy Last add: Oct 6th FT8 VHDL GFSK modulator
guidoGuido 08/16/2023 at 20:140 Comments
According to the previous evaluations (see previous logs), I should build something like this:
are two Vivado IPs receiving the 8 + 48 bits from a GPIO standard Vivado IP
