TinyUSB + Raspberry Pi Pico = USB-Readable Psion SSD!
A project log for PsiDrive - A USB Psion SSD Drive
A USB drive for modern computers that reads Psion's proprietary SSDs, using an RP2040.
alex-brownAlex Brown 08/13/2022 at 07:221 Comment
Just a quick update: After spending a few hours playing with the Adafruit version of TinyUSB for Arduino, I can now see a Psion SSDs as block devices in Linux!
The status is:
This is a screenshot of a RAM SSD mounted from /dev/sda (note: no partition table on these), being read by Linux like it was just another USB drive.
So yeah, this is the closest I've come to having an actual USB SSD Drive. I have a lot to learn about TinyUSB, as I feel like I'm just scratching the surface of its potential. I also still need to write the routines for writing to Flash I and Flash II SSDs in libsibo, plus rig up a 17.5v supply. I'm also quite far into designing a test PCB with through-hole components.
More to come soon!
balicota wrote 10/16/2022 at 12:02 point
There is a product called "Cyclone Floppy Drive" made by "Purple Software".  It is a hardware emulator from  a standard floppy drive to the SIBO serial bus.  While it is unsure it would help you with emulating every type of ASIC, it certainly might give you some insights in the writing portion.  But it certainly is possible building a USB or SD card drive connected to the serial bus.
