Finally an original V9958! 8th order!
A project log for MSX1 Homebrew Clone for Baffa-2 Project
Project codename "Baffa-X" is a set of boards to make a MSX1 Clone for Baffa-2 Homebrew Computer
augusto-baffaAugusto Baffa 04/05/2023 at 21:164 Comments
As we know, the V9958 package has no notch (hole). All fake V9958 have the same code 2703 2122 IACC, and we can notice the painting of the label that is different. (the last one at bellow is the original IC)
Andrew Lynch wrote 3 days ago point
Hi, I ordered a V9958 from the link Augusto posted and received a genuine V9958.  I've tested in my Media IO board and it works fine.  It is obviously a used pull with resoldered legs and looks kind of roughly treated.  However, it is a dramatic improvement over the string of fake V9958s I've gotten of late though.
Andrew Lynch wrote 03/10/2024 at 13:38 point
Hi,
I am working on a project using V9958 and am having same issue with fakes.  Where did you get your legitimate V9958s?  Thank you!
Augusto Baffa wrote 03/10/2024 at 15:25 point
Hi, I got at Aliexpress. My last order was in last april...  https://pt.aliexpress.com/item/4000448535456.html?spm=a2g0o.order_list.order_list_main.106.781acaa4IWdE40&gatewayAdapt=glo2bra
Barry Kelly wrote 04/28/2023 at 13:43 point
Hi Augusto, I'm having the same trouble trying to source a real v9958.  Is there a source you'd recommend?
