MMBASIC on Small RP2040 Card
Card set running BASIC Interpreter for the Raspberry Pi Pico on Seeed Studio XIAO RP2040
Running MMBASIC Interpreter for the Raspberry Pi Pico on Seeed Studio XIAO RP2040.
MMBasic is a Microsoft BASIC compatible implementation of the BASIC language with floating point, integer and string variables, arrays, long variable names, a built in program editor and many other features.
  • 8 Flash locations for storage
  • Support for SD Card
  • Optional RS-232
Running PicoMite MMBasic Version 5.07.04. (Not VGA sersion).
Program:
   0K ( 0%) Program (0 lines)
 124K (100%) Free
RAM:
   0K ( 0%) 0 Variables
   0K ( 0%) General
 156K (100%) Free
MMBASIC Credits
Peter Mather led the project, ported the MMBasic interpreter to the Raspberry Pi Pico and wrote the hardware device drivers. Geoff Graham wrote the MMBasic interpreter and the manual. Mick Ames wrote the PIO compiler and its corresponding documentation.
Hardware
  • RS-232 Serial Interface Option
    land-boards.com08/19/2022 at 13:01 0 comments
    Adding an optional RS-232 interface.
    Using DTE card.
    Wired to D6, D7, +3.3V, Ground on QTPy49-01 or QTPy49 card.
    Pinout for J4 on QTPy49 cards:
    1. GND
    2. 3.3V
    3. TX, D6
    4. RX, D7
    Tx on QTPy cards to Rx on DTE card.
    Loopback on RTS/CTS lines on the DTE card satisfies hardware Handshakes.
    Setup in MMBASIC
    OPTION SERIAL CONSOLE GP1, GP0
    Runs at 115,200 baud.
    Stackup
    Using 4-40 standoffs for stackup.
    With DB-9 Breakout and FTDI-49MM plus DCE cards.
View project log
