LRMS Revision 2 PCBs - 3D models
A project log for LoRa End Node & Remote Monitoring System
A LoRa remote solar powered monitoring system designed to be as flexible as possible and connect to a variety of sensors/sensor modules
jstuartjstuart 08/11/2022 at 23:190 Comments
I have been working on revision 2 of the LRMS boards. Component placement is completed and I will be routing
Transceiver and gas sensor boards.
LRMS LoRa Transceiver R2
Revision 2 :
LRMS Environmental Gas Sensor
LRMS MPPT Solar Power Module
