• First video presentation
    dumitru.stama12/11/2016 at 02:57 1 comment
    I finally managed to upload a video in which I talk a little bit about what an RTOS is and then I step through the code to show you the big building blocks.
    I will try to upload some technical presentations as well soon.
    Here is the youtube link :
  • Stack layout (revisited)
    dumitru.stama12/03/2016 at 15:45 0 comments
    I realised I made a mistake with the last diagram and used MSP for indexing instead of PSP.
    I corrected the image and re-uploaded to this project.
    Here it is as well :
  • CALL and RET
    dumitru.stama12/03/2016 at 07:24 0 comments
    A few people asked me why I defined these two macros in the assembly source file.
    There is nothing wrong with "bl subroutine" or "bx lr" but these two macros help me read the code faster when I look for specific subroutines.
    I call it "professional defect" since most of the days I stare at Intel assembly and I am used to mentally separate code blocks in a specific way.
  • Task Stack
    dumitru.stama12/03/2016 at 06:44 0 comments
    Here is how a task's stack looks like when the scheduler activates :
    First part (top 8 registers in the diagram) is automatically saved by the interrupt handler, the remaining 8 registers are saved by the following code :
    stmia r1!,{r4-r7}  // store r4-r7 and increment r1 for each one
    mov r2,r8          // r2, r3, r4 and r5 are already saved
    mov r3,r9          // so we can use them as intermediary regs
    mov r4,r10
    mov r5,r11
    stmia r1!,{r2-r5}  // registers are in order on stack r4...r11
  • Rock-solid functionality
    dumitru.stama12/03/2016 at 05:53 0 comments
    I used to get random faults from time to time and these things are quite hard to debug. After a lot of hours I managed to finally isolated the issue in the mutex handling system.
    I redesigned the system, it's much more robust now and it didn't fail yet like the old system.
    Good part: I have 32 max mutexes now since I store them as bits into a word
    Bad part: I had to remove the string from the code :) It's now 1024 bytes without any string.
    I will try to optimize some more size-wise so I can put back the string at least partially.
    On another note, some more docs are coming, stay tuned !
  • Better sleep
    dumitru.stama12/02/2016 at 03:58 2 comments
    I replaced the infinite loop in the idle task with "wfi" instruction. Theoretically this should put the processor to sleep until the next systick interrupt and this will save energy. I said theoretically because it needs some setup but it seems to work out of the box so I will keep it as an option.
    I also uploaded the RAM memory map.
  • Documentation
    dumitru.stama12/01/2016 at 06:35 0 comments
    All sources are fully commented but proper video documentation will follow in the next couple of days.
    If there is enough interest I might even make a step-by-step building videos.
    Stay tuned
