Neoprene vs Craft Foam
A project log for Otter's Cap
If Otter falls and hits the top of his head, it can damage his brain, even be fatal; so we're trying to keep this area soft,padded,and safe.
brucejdiibrucejdii 08/13/2022 at 00:010 Comments
You can pick up inexpensive 1/4 craft foam at Michaels, the neoprene wasn't pricey either... however The Craft Foam wasn't AS pliable as the neoprene; although you can heat shape the Craft Foam with a heat gun/ blow dryer...
