HydraUSB3 V1 is an open source developer kit for the WCH CH569 MCU to experiment with streaming / high-speed protocols like HSPI and SerDes through USB3. It allows to test and discover the MCU main features, like:
HydraUSB3 V1 Evaluation Board / Dev Kit and test firmware are not linked to HydraBus v1 hardware/firmware projects and will not replace it.
HydraUSB3 support natively dual board connection (without requiring any wire/cable except for SerDes connection which requires 2 wires for GXP/GXM)
HydraUSB3 V1 Board
HydraUSB3 V1 are available now on digikey.com HYDRAUSB3_V1 / 3792-HYDRAUSB3_V1-ND, Pack of 2x HydraUSB3 v1 boards are available now on HydraBus Store HydraUSB3 V1 is produced using components with Operating Temperature -40°C / +85°C (or more), the MCU WCH CH569W Operating Temperature is -20°C / + 85°C. Caution HydraUSB3 V1 is an Electrostatic Sensitive Devices Do Not Handle Except at a Static Free Workstation.
HydraUSB3 open source test firmware / API: See github: https://github.com/hydrausb3/hydrausb3_fw For more info on open test firmware or hardware for HydraUSB3 see https://github.com/hydrausb3/hydrausb3_fw/wiki/Getting-Started-with-HydraUSB3
HydraUSB3 V1 package content:
Overview:
