Minor update
A project log for Vinyl cutter for Ender 3 v2
An adaptor to allow a drag knife cutter to be fitted to an Ender 3 v2
robgRobG 08/18/2022 at 12:210 Comments
After a bit of trial and error, these are the settings I'm using on my Ender 3 v2 (other printers will be different):
minimum X position30mm
maximum X position220mm
minimum Y position0mm
maximum Y position220mm
Z position during cuts2mm (note 1)
Z lift during travels+4mm, i.e. Z=6mm
Z speed10mm/s (note 2)
(note 1: for paper/vinyl. Increase this accordingly for thicker materials)
(note 2: needs corresponding increase in the max Z speed, via the menus on the printer's controller)
