~Specs~
Cpu
8gb DDR4 Ram
256gb Sata SSD
7" Waveshare Touch Display
UT 47 Keyboard W/ Backlight
Double Retrocart 5w stereo speakers
TL-WN722N wifi dongle
UB500 wifi / bluetooth dongle
3s4p 8.8AH Battery
~Made Parts~
~3mm acrylic~
1x Switch Plate
1x Middle Plate
1x Bottom Plate
1x Front Plate
1x Back Plate
2x Bottom side plate
~Resin Printed~
2x Top front corner
4x Bottom corners
1x Speaker Side panel
1x Speaker Side Panel Mirrored
1x Bottom side support
1x Bottom Side Support Mirrored
2x Retrocart socket
1x Top Rear Corner 1
1x Top Rear corner 2
~Fasteners (mcmaster #'s)~
x12  90362A114 m3 x 8mm Stainless torx pan head
x12  91828A211 m3 nut
x75 96817A892 M2.5 x 6 Stainless torx Thread Forming screws for thin plastic
x4     96754A107 18-8 x 1.5-1.625" Stainless Tamper resistant Torx Binding Barrel and screw
3M VHB Tape
~Tools~
x 2 3584A234 45ga 0.082" Drill bit (tap size for M2.5 plastic screw)
x2 T20 Tamper Resistant Torx L-Key 55525A27
x1 T8 Torx Bit
x1 T10 Torx Bit
Soldering station
~Switchplate~
gnap U47 (gnap 2.0) keyboard PCB
47 Cherry Mx switches
x2 Pro Micros one flashed with ut47 firmware and the other flashed with ut47 arduino sketch
x47 1n4148 diodes
x47 3mm LEDS
x4 0.25W resistors
keycaps
Waveshare 7" Display
~Frame~
2 Cherry MX Switches
2x usb A Breakout
2x 5w speakers
30x30x7.5 5v fan
usb c pd trigger
~Compute~
Laptop Pcb
Laptop Usb Daughter Board
Laptop Sata Daughter board
Laptop Power Button Daughter board
Retrocution Usb Hub
2x Micro usb cable ends
3x usb a female breakout
1x 8 pin male laptop battery connector
256gb Sata SSD
2x 4gb DDR4 Ram
Hdmi Ribbon Cable (Downward angle to standard)
