Bar LCD Music Player
Building a standalone music player using the Majoca Iris bar LCD Display
Working on a half-1u standalone Spotify frontend using a salvaged 640x48 LCD.
CAD and code to come once this is in working order.
  • My printer is too small for this enclosure
    nathan.matsuda08/19/2022 at 19:10 0 comments
    After the breadboard-level mockup of this music player was working, I wanted to see how well this would fit into the roughly half-1u form-factor I was aiming for. To do this, I needed to get the display and buttons onto some sort of chassis. I decided to try out JLCPCBs board fabrication and assembly service, which I've been meaning to do. It worked out quite well.
    I've been using a Lulzbot Mini 2 for a couple years, which works great but is too small for a lot of my uses. I end up having to bolt parts together from smaller pieces, which I did here as well.
    Once I've settled on the button layout and overall dimensions then I will either send this out to print in fewer pieces, or possibly try to use FrontPanelExpress to make a partially aluminum enclosure or something like that.
  • Using a 640x48 graphic LCD
    nathan.matsuda08/19/2022 at 19:03 0 comments
    Back in late 2020 Twitter user @kakocom posted the first of a series of tweets outlining how to salvage an unusual 640x48 bar LCD from a kid's toy. There was a flurry of activity, with a few notable developments including @lovyan03 adding support to the LovyanGFX library, and @devemin releasing FBTFT support for the Raspberry Pi. Much of this development is logged on @pcjpnet's very helpful github repo. I heard about all of this via @bikerglen tweeting about the display stateside.
    At the time, I was thinking about how to make a less visually obnoxious Spotify player, and was looking at a lot of bar LCDs for a rack-mount status indicator project. This little bar LCD seemed like a great way to make a half-1U standalone player. I ordered Glen's featherwing design from OSHPark and breadboarded the basic setup.
View all 2 project logs
