Shoes Mount Design
A project log for Footwear Cooler
To develop a water cooler to regulate the temperature of the feet or for some people with hot feet problem
revoxdynaRevoxdyna 08/26/2022 at 11:330 Comments
The requirement for the shoe mount is simple:
able to mount on a shoe tightly
I had a quick thought and designed a mount and test.
The following is the result.
It fit the shoe perfectly, however, it could not fit into another shoe. Therefore, the shoe mount must be modularized (design a mount for a special type of shoe) or add a degree of freedom to adopt more shoes.
The following is the design up to this moment. The moving parts would be self-assembled during 3D printing. This is the first time I tried to use this technique and the result was acceptable.
