A few more tests were conducted to get the performance.
Objective:
- To measure the max. temperature difference.
- To get the time for the steady stage
Experiment setup:
Data of the cooling:
Data of the water tank:
Results:
- The max. temperature difference of the insole was 4.9 deg
- It took around 25 mins to get the steady stage
- The max. temperature difference of the water tank was 5.5 deg
Conclusion:
Although the temp. different was 4.9 deg, the water droplets were condensed on the insole and cooling pipe already. After the testing, I put my feet on the cooled insole and the cool feeling ran through my feet.
