Repurposing a PLC clone for use with Arduino
It is fairly common to find in online shopping pages, advertising like this: “Industrial control board compatible with FX1N, FX2N, FX3U and programmable with GX software”. The price is attractive, however, the documentation is non-existent, and there is no mention of how to program it with other tools like Arduino in other operating systems different from Windows. This article will introduce a few key concepts to help solve this problem.
Industrial control board compatible with PLC programming software of a specific manufacturer
Key component: Industrial control board compatible with FX1N
Attack of the clones
These boards mention compatibility with GX software, which is manufactured by a Japanese company that makes PLC and also cars. At first sight, the compatibility is not official, as no trademark is printed. Their origin is unknown, maybe they were simplified copies based on original schematics and source code, or somehow the native binary format of the PLC was reverse engineered and an interpreter was built and runs in the microcontroller translating the code. Most of the cards are based on STM32 microcontrollers, and according to some articles and videos, the original programming software actually recognizes them as an original PLC!
Plastic enclosure, DIN rail installation
Due to their low cost (around $25 USD), and for their relay isolated outputs, optically isolated inputs, RS232 serial port and regulated power supply, are great candidates for small projects as long as they can be programmed with a free multi-platform tool like Arduino or STM suite. In addition, a schematic diagram is needed to find out which I/O of the microcontroller goes to which peripheral in the board!
Bill of materials
Parts used
COMPONENT DATASHEET  -  BUY LINK
Pinout for industrial control boards - repository
OPTIONAL COMPONENT DATASHEET  -  BUY LINK
Reprograming
The aforementioned board, sports a STM32F103 microcontroller, so instinctively a footprint for a SWD programming header should be looked for.
Possible programming header footprint at lower right
After following the tracks of this header, one pin was found connected to 3.3 V, another one to GND, but the other two pins were not connected to SWD pins on the microcontroller but to PC10 and PC11 pins. Starting the search from the microcontroller, there are no tracks from SWD or USB pins, so the only alternative available for reprogramming is through UART1 using the bootloader stored in ROM
Serial port related components
Following the tracks leaving from the DB9 connector, they end in an unmarked chip, however, due to the nearby capacitors it is probably a MAX232 or equivalent. Following the tracks leaving from this chip they end in PA9 and PA10 pins of the microcontroller which are the UART1 pins.
Luckily in this board, the resistor which is connected to the BOOT0 pin is clearly marked on the silkscreen. To start in bootloader mode, a male header was soldered to the 3.3 V pad, and using a Dupont wire jumper, a temporary connection between BOOT0 and 3.3 V is made while the board is powered up
Method used for bootloader activation
Once the bootloader was running, STM32CubeProg was launched and communication with the microcontroller was verified. The chip was in read protect mode, so no way to backup the firmware to reverse the board to its original state. All FLASH memory has been erased.
Using Arduino IDE, it was proceeded to the installation STM32duino core and to make a small test application that sends data through the serial port to the PC. The app was downloaded and the incoming data verified. Now the adventure starts!
USB to RS232 converter and connectors used for communication check between PC and board
Identifying I/O pins
Because of the lack of a schematic diagram, or marks in the silkscreen showing which microcontroller I/O pins goes to which peripheral, this work must be done manually, with a lot of patience to follow the tracks. Fortunately the board has only 2 layers, so it is possible to start with only a double-eye magnifier for jewelry and a multimeter.
LED and switch
The board has two LED indicators, one labeled as RUN an the other labeled as ERR. Additionally, there is a switch that was used by the old PLC firmware to stop program execution. Due to these peripherals have a few elements between them and the microcontroller, they are very easy to start with.
Microcontroller I/O pins connected to LED indicators and switch identified
The pins were found mapped as follows:
ELEMENTPIN
LED RUNPB12
LED ERRPB13
RUN/STOP SWITCHPC9
Digital inputs
Digital inputs were relatively easy to find, because the tracks leaving the optocuplers went directly to the microcontroller. Only a few ones were tricky because they jumped to the opposite layer or traveled under a big component.
Following input tracks
ELEMENTPIN
X0PA0
X1PA1
X2PB9
X3PA6
X4PA7
X5PB5
X6PB4
X7PD2
Digital outputs
The digital outputs took the most effort, because the tracks went first to an UL2003 chip, and from there to each relay, traveling under components or jumping to the opposite layer. Multimeter was crucial to follow the tracks.
Following output tracks
ELEMENTPIN
Y0PB8
Y1PB1
Y2PB10
Y3PB0
Y4PC5
Y5PC4
Analog inputs
The analog inputs were relatively easy to find, because they are only 3 and they are connected only to a voltage resistor divider (15 K/30 K) between them and the microcontroller.
Following analog input tracks
ELEMENTPIN
ADC1PC1
ADC2PC2
ADC3PC0
Final touches
At this point, all peripherals are mapped to the microcontroller I/O pins, however, whenever the board needs to be reprogrammed, BOOT0 needs to be set to 3.3 V using a temporal wire jumper, which implies opening the enclosure. A quick fix will be to connect a wire from the BOOT0 pin to the RUN/STOP switch used by the old PLC firmware, in this way the ROM bootloader could be initiated externally without opening the case for reprogramming
External switch now wired to BOOT0 pin
Summarizing
At this stage, you have a low cost board with enough peripherals for small experiments without requiring additional hardware and can be programmed using Arduino IDE or STM suite. To replicate this experiment with a different board (as long as the CPU has been identified) follow the steps below:
Possible improvements
Create a skeleton application as a boiler plate for each program for the board, this application should have some kind of mechanism that checks the condition of the RUN/STOP switch to decide whether to go to ROM bootloader or start executing the program stored in the FLASH, This eliminates the need for an electrical connection between BOOT0 and the switch.
Another option, if a skeleton app is not desired, is to make a bootloader stored in the FLASH that uses UART1 for communication, similar to the one stored in ROM, but this one checks the condition of the RUN/STOP switch to decide whether to download a new program or executing the program stored in the FLASH
