Design Description
A project log for Zinnia (MCPU5)
8 Bit CPU implemented in 100x100µm² IC area for TinyTapeout
timTim 09/06/2022 at 20:320 Comments
Top level
The strict limitations on I/O do not allow implementing a normal interface with bidirectional data bus and separate address bus. One way of addressing this would be to reduce the data width of the CPU to 4 bit, but this was deemed to limiting. Another option, implementing a serial interface, appeared too slow and too complex.
Instead the I/Os were allocated as shown below.
The CPU is based on the Harvard Architecture with separate data and program memories. The data memory is completely internal to the CPU. The program memory is external and is accessed through the I/O. All data has to be loaded as constants through machine code instructions.
Two of the input pins are used for clock and reset, the remaining ones are reserved for instructions and are six bit in length. The output is multiplexed between the program counter (when clk is '1') and the content of the main register, the Accumulator. Accessing the Accumulator allows reading the program output.
Programmers Model
Besides simplifying the external interface, the Harvard Architecture implementation also removes the requirement to interleave code and data access on the bus. Every instruction can be executed in a single clock cycle. Due to this, no state machine for micro-sequencing is required and instructions can be decoded directly from the inst[5:0] input.
All data operations are performed on the accumulator. In addition, there are eight data registers. The data registers are implemented as a single port memory based on latches, which significantly reduced are usage compared to a two port implementation. The Accu is complemented by a single carry flag, which can be used for conditional branches.
Handling of constants is supported by the integer flag („I-Flag“), which enables loading an eight bit constant with two consecutive 6 bit opcodes.
Instruction Set Architecture
The list of instructions and their encoding is shown below. One challenge in the instruction set design was to encode the target address for branches. The limited opcode size only allows for a four bit immediate to be encoded as a maximum. Initially, I considered introducing an additional segment register for long jumps, but ultimately decided to introduce relative addressing for conditional branches and a long jmp instruction that is fed from the accumulator.
Having both NOT and NEG may seems excessive, but the implementation was cheap on resources and some instruction sequences could be simplified.
No boolean logic instructions (AND/OR/NOT/NOR/XOR) are supported since they were not needed in any of my typical test programs.
grafik
The table below shows common instruction sequences that can be realized with macros.
grafik
