debugging rabbit hole
A project log for SensorWatch UV Sensor
Add SI1133 Lux and UV sensor to SensorWatch, a Casio F91W drop-in replacement
wesley-ellisWesley Ellis 11/02/2022 at 01:080 Comments
Going down a bit of a rabbit hole at the moment and trying to get the SWD pins broken out of the SensorWatch 'In system' (aka with the watch assembled). I need that so I can have a faster iteration cycle and so that I can start logging some data while the sensor is in it's natural environment
I have some very fine gauge wire attached to the pads and broken out. Those wires are also attached to a 10-pin debug connector and to a J-Link mini, but it's not working properly... I suspect some mis-wiring on my part but it's hard to check connections with such tiny wires and connectors. To fix that, I've ordered a breakout board
