Can we make it gain more linear and boost some more
A project log for Audio - Phono preamplifier boost
Clean hack of the otherwise very solid ART DJ-Pre II phono preamp with the aim of improving the existing design and enhancing its features
jovanJovan 09/21/2022 at 00:540 Comments
That previous work partially presented in previous post prove to be good mod. That modified ART DJ Pre - II works stable and objectively measured much better then in original configuration. But now I have something even better, observing the position of Gain for my Pioneer Pro-DJ PC-X5 cartridge, which is no other then branded(OEM) AT-3600L i get puzzled why it needs the same ~+4 Gain trim which is like +39-40dB on printed scale, and on the other hand on my made Lab-Preamp (that metal box at my wok bench pics.) measurements shows that it can be put on +34-35dB to get same -1..-3dB signal levels. So I took of little 5k gain pot and find out source of problem is non linear etc. its logarithmic nature of strange applied amplification design.
It look like this:
Vin-mV Vin Vout-5k-1M-OFF Ohm Position Vp-p (V) avg(3x) +dB
10mV 0,01 "-10 Begining" 5302 0 0,294 0,294 29,36695
      5006 1 0,295 0,295 29,39644
      4001 2 0,296 0,296 29,42583
      3003 4 0,312 0,312 29,88309
      1980 5 0,324 0,324 30,2109
    "1/4" 1400 3 0,336 0,336 30,52679
      987 6 0,372 0,372 31,41086
    Zero "0" at 50%  681 7 0,488 0,488 33,7684
      467 8 0,704 0,704 36,95145
    "3/4" 25% 84,5 9 1,73 1,73 44,76092
    "+10 End" 2,5 10 1,7851,484945,03
In short by "fixing" inverse log position of DJ Pre II by switching to new 2,5k Lin pot. we can get almost linear selection of gain:
2K5 Lin potenciometar Position in % Omh no Vpp "+dB"
10mV 0 2500 0 0,56 34,96376
25   1 0,64 36,1236
33,3   2 0,69 36,77698
50   3 0,88 38,88965
66,7   4 1,09 40,74853
75   5 1,88 45,48316
100   6 4,92 53,8393
To get beyond +45dB up to that +53.8 gain, you need to disconnect Pot pin 1 and 4 or to bypass then with 100k-1M Ohm.
If you omit those resistors for Pot bypass (left open pin 1-2, 4-5) you will get no more then +53,9dB at the best.
So until my 2k Lin Burns (2 gang - stereo) Potentiometer arrives box stays open.
Best regards,
dr Jovan I.
