[M] Optical Path for 2560px Microdisplay
A project log for T^2 TyMist [gd0138]
I need some virtual desktop monitors that offer 90PPD at 90Hz.
kelvinakelvinA 01/30/2023 at 16:530 Comments
I've hopefully got a new solution for the optical pathway, and I should have a better understanding of how things should work out.
A possible thing that is incorrect is that I'm using the 10mm eyebox. Maybe I'm supposed to use the larger 12.5mm diameter FOV circle (see below) or be using 18.4mm as the screen size in the simulation instead of 23mm. Maybe this just means the actual eyebox is 10mm * 10/12.5 = 8mm, which should still be servicable.
