[M] Optical path refinement
A project log for T^2 TyMist [gd0138]
I need some virtual desktop monitors that offer 90PPD at 90Hz.
kelvinakelvinA 01/31/2023 at 12:370 Comments
The distance from the top of the fresnel to the top of the helmet (above the fresnel) is just over 10cm:
That means that the optical path I had probably was going to intersect with the user head area.
I've got this new path that has a couple of benefits:
The steepest angle emmited from the screen is under 15 degrees, and according to this blog post (see below), the OLED brightness at a given angle is cos(angle) * 100%. The result for 15 degrees is 96.6% brightness so I'd probably never notice. I wouldn't be suprised if I see steeper angles from normal sized OLED panels.
Overlaying the path, it seems that I've still got space to go up even further, perhaps to allow more head padding space.
